Folks,
I'd like to understand a bit more about the difference of high mass and low mass ovens in a practicable construction sense. I'm reasonably comfortable that I understand the difference in terms of how the oven performs, but I'm not sure of the real life construction differences.
What construction characteristics constitute a low mass, medium mass, or high mass oven?
For example, if i build an oven using 115mm (4.5 inches) wide fire bricks as the internal wall, followed by a 25mm (1 inch) insulating ceramic blanket, followed by a 40mm (1.5 inch) insulating castable render, and then either more render, or a second skin of solid red bricks, then;
What sort of oven have I built in terms of heat mass? High, Medium, or Low.
To change the heat mass rating and move it up, what would I do? Just add more to the insulation layers? Add a layer of something (not sure what?) before I lay the insulating layers?
I guess that while I generally understand the difference between the heat mass layer and the insulating layer, I'm not sure exactly how they work hand in hand, given that I guess at some point the insulating layer should be contributing to the mass layer by holding the heat. Also I'm not sure how to directly increase the heat mass layer apart from another layer of fire bricks, but I'm sure there are other more practicable and affordable ways to do this.
I guess to add some context, I have this plan to build twin ovens that currently stands at one smaller sized dome oven, and a larger tunnel design. The small one primarily for pizza's, and small roasts that is quick to heat, and the larger one for big cook ups, potentially in tandem with the smaller oven. At this stage apart from basic design shape differences, construction plans are similiar in terms of bricks and insulation. My prefrence would be lower mass for the smaller oven (quicker to heat, not required for extended periods), and higher mass for the larger oven, but I'm not sure where my basic plan that I described above sits in terms of mass rating, so i don't know how to fine tune the construction plans to get what I think I would like.
All advice/explanation appreciated.
Cheers,
Peter.
Cheers,
Peter.
