Re: Aussie Readers
Hi Paul,
I have only just started laying my isulation bricks on my hearth so am not too far into the project I have begun a thread that can be located at http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
I notice you are from Newcastle so my supplier will be a bit of a hike for you.
You can check them out at Field Furnace Refractories
They offer a package for a 1 meter internal oven at a cost of AUD $1,300.00
Quantity Description Unit price Total
120 Fire brick. 230x 115x 75mm $3.30 $396.00
12 Floor tile 50 x 300 x 300mm $14.90 $178.80
5 High temperature mortar 25kg bag $33.00 $165.00
48 Insulation brick I.F.B 230x115x75mm $3.30 $158.40
2 Ceramic fibre roll 25x600x7200mm $110.00 $220.00
14 Door arch brick 230x115x75/S1mm $3.70 $51.80
10 Flue arch brick 345 x 115 x 75/63mm $6.00 $60.00
8 Flue arch brick 345x115x75/51mm $6.00 $48.00
4 Flue brick 345x115x75mm $6.00 $24.00
Total AUD $1,302.00
3 Vermiculite (If required)100litre bags 6kg $28.60 $85.80
For a 42 inch oven I will use about 70-80 insulation bricks
I am also going to lay the fire bricks for my floor rather than the Floor tiles so the cost just keeps on going up!!
Good luck !!
Originally posted by Alter ego
View Post
Total AUD $1,302.00
Good luck !!
