Re: Aussie Readers
You want enough cement in the mix so it will be hard enough to render onto, but the more cement you use the worse the insulating performance will be. I use 10 parts vermiculite, 1 part cement, 3 parts water (by volume) You'll think "this'll never work," but it does. Mix it dry in a large bucket before adding the water.
