Hi All,
I'm about to embark on a 42" Pompeii oven. I've assembled all the materials but I'm having trouble finding anything readily available in Kenya to use as the insulating blanket between the brick dome and the vermicucrete insulating layer (I'm building an igloo design). Does anyone have any suggestions about what to use? Can I eliminate the the insulation blanket and just beef up the vermicucrete layer? There is a vermiculite mine just near Nanyuki and I can get as much vermiculite as I need. My impression is that the insulation blanket serves as a sort of expansion joint as well as an inulsation blanket and that building the vermicucrete layer right on the bricks will result in cracking sometime in the future. Can I just leave a 1/2 air space and be done with it? Any advice will be apprciated.
