Hi All,
I am working on my first proper oven. the first one I built burnt well, but wasn't well insulated enough. mark two is bigger, better and being built almost entirely from reclaimed materials.
It has an internal diameter of 900mm. I have built the base and cut a fire brick floor to fit inside the circular walls. (Firebricks from old night storeage heaters). I am struggling to find a way to build the dome that I am capable of doing. i have two ideas.
1. form a dome shape in pliable wire and then build over it.
2. Step in each course of bricks by about a third of a bricks width so that it gradually goes in and will eventually meet. I could smooth over the "steps" with mortar if it is necessary.
What do you experts think?
Look forward to hearing from you.
Nick. (Badsey, England.)
