I've been reading multiple posts discussing the costs/benefits of adding insulation under the oven floor and/or making the floor thicker, but I'm still confused. I'm designing a 42" WFO mostly for bread for family/friend use, but pizza parties too. My wood sources and time are limited. Can anyone explain to me:
(a) Is it beneficial to have more than 2" of FB Board under the oven floor? Can you never have too much insulation under the floor (or over the dome)? I was thinking of using 1 layer of FB Board between the cement hearth and oven floor, but would it be beneficial to put 2-4" of vermiculite concrete in there as well, or 2 layers of insulating board?
(b) In combination with more insulation, what is the effect of adding thickness to the oven floor, such as turning the bricks on their side or adding splits? Longer firings but longer heat retention? What about temperature? I am hoping for relatively quick firings for relatively small quantities of food (a few pizzas and 6-10 loaves of bread). It sounds like the standard 2.25" floor should be fine. Will a thicker floor contribute to scorching or do anything else to the cooking process itself? Should I consider it if I may want to do 2+ batches of bread?
I wish I could just "try out" both and see what works, but it seems there's no turning back once it's built.
...enjoy every sandwich!
