Hi, I'm getting going with my Pizza oven in Aberdeen, Scotland. I'm relying heavily on the information I get from the FB plans and this Forum. I'm living in a cold country in the Pizza oven wilderness and people here think I'm crazy. I managed to find a supplier for some of the stuff I need to build a good oven down south in England but some of the stuff they have given me isn't up to scratch. The staff are not much help. They don't know about ovens. just answering calls, not questions.
I'm building an oven slightly bigger than the 42 on the FB plan. They supplied me with a 4 inch flue pipe which I'm returning. I know from reading my FB Bible I need at least an 8 inch.
I ordered a special Pizza oven door from them that is cast iron and has glass and a thermometer in the glass. It comes in a Frame. MY FIRST QUESTION... The frame is going to create a lip at the entrance to the oven.
The frame opening is about 15 inches wide and 10 inches high. This is good for stopping heat escaping but will make it impossible to get inside the oven for cleaning well or reparing. The lip could be recessed on the inside but because of the door design it will mean a drop in floor level for the door on the outside.
Should I keep this door or live without one?
I'm not sure if I should return it with the flue or if the door is a big advantage that the small lip and entrance is worth living with...
I was about to cut all the floor base bricks to fit inside the oven chamber walls but then if I can't get into the oven to replace them it seems pointless.
Any advice would be most welcome.
