Hi all,
I'm new to the fornobravo forum but a member of the uk wood fired oven forum. One of the folks from there suggested I check out this forum - so much info! I'll be spending a fair bit of time on this forum I can tell.
I've looked through using certain search terms (shelter, roof etc), but can't find quite what I'm looking for. Hopefully someone can help.
I've built a pizza oven with a Stonebake modular oven as the base. Picture 1 - no laughing, I'm no builder
However a couple of things...
1) The vermiculite / render has cracked slightly with the heat. Won't affect the oven but means I have to cover it in tarp when not using and this looks rubbish.
2) Which also means I can't use it in the rain!
So I'd like to build a shelter over it so it can be used all year round.
Originally I wanted a cantilever shelter (picture 2) but have since been convinced that this wouldn't be possible because of the forces on the structure (the pic above is a pergola without a solid roof. Adding a roof would mean more force from wind, weight of snow etc in the winter).
So it's looking to be something like the final photo attached (pic 3 - dark brown wood). The problem is I don't know a thing about building / construction, so not sure of the best materials to use for the roof, how to put the flue through it and to seal it. I know I'll need a twin wall adapter to go to the roof, but that's about it.
Has anyone here done something similar? If so any info / advice would be greatly appreciated!
Jon
Jon
. There are quite a few builds with roofs over their ovens, but not too many with the kind of area I was looking for. The Dragonfly Den was one of the ones that provided some detail, and Mike has posted quite a bit of information via his build thread and picture album. You should be able to find his oven with a forum search for Dragonfly Den or SableSprings.
