Am building 36'' inner size oven. My questions are following:
1. What should be the distance to inner Arc from cicle center? (see image).
2. I'll have a mix of sand and fire clay under floor bricks, but shouldnt i mortar the most outer floor bricks? Wont they move under weight vertically or horizontally when there is just sand/fireclay under them?
3. Can i use just normal full bricks and flexible tile mortar to entry arch? (distance from inner arch will be 12'' and just arc bricks would be normal full bricks, the rest would be fire bricks)
thank you.
thank you.
