I came across a stream about how to figure out the angles that are cut into the interior face of the arch bricks, yet I am still struggling with how these angles are found. I am pasting the most helpful post I found to date but I still can't decipher what is actually happening, here is the post...
I finished off my second course and incorporated the first of my tapered arch bricks. Got about 1/3 of course 3 before I ran out of mortar and daylight. The joint thickness on the arch bricks is a little thicker than I wanted so will have to keep an eye on that. Ran into a little confidence crisis on cutting the back angles on my arch bricks, but UtahBeehiver has been helping me through the visualization and I think I am on the right track. That is one of the great things about this forum - knowledgeable people that are willing to help. Having someone to talk things through seems to really stimulate the thinking process. I had to put my marker back in the IT and trace the outline of inner and outer surface of the dome on my arch bricks. I saw this in UtahBeehiver picture gallery, but needed a little help understanding how it all fit together. I clamped a brick in the IT and brought it up next to my TDC arch brick, aligned it with the inner and outer marks, and established the angle needed for the brick to seat. I have no idea whether it will be a full width brick or a sliver when I incorporate the last course into my arch, but I have a good feel on how it will sit. I will use those marks I made on the balance of the arch bricks to cut them to shape as I build up.
or just anyone who can define this process for me. I am really struggling with this one.
The angle of the brick is set by aligning the top edge with a line on top of the TDC brick representing the oven outside surface (pic 2). Then I cut the angle on top of the TDC brick so the dome brick would be tight on the inside and allow a mortar joint to the rear as shown in the last picture. Does this make sense?
