In your "what to do here" space between the two arches, all I did was make sure I had about 1/4 inch air gap and just left it empty. I used one run of rope on top of my inner arch, and with as "grabby" as the bricks were I thought the rope was sufficiently secured. I filled the exterior of the gap with the high temp sealant, but in retrospect I don't think that was necessary as when I rendered my igloo the stucco flowed into the gap and sealed it off. There may be a better way to do it but it escaped me. I don't think my rope is ever going to move, and if any particles break off they will hopefully just fall down and lay on top of the arch. That is the beauty of not having any rope in the vertical gap - don't need to worry about falling fibers or how to retain the rope.
I went back and looked at my post #149 and remember the pic. I had thought about doing the angle to help with smoke flow, but can't remember why I didn't. I think I was cutting the bricks late in the fall after daylight savings ended and was just trying to get all the cuts done.
