Hi there you guys first of all HAPPY NEW YEAR. I am moving my thread from the introduction forum so all newbies can follow my first ever wood oven. it is done with a gym ball. The first layer is a 2-inch thick layer of the Home brew sand, cement, line, clay mix. Following recommendations I will cure it covered with wet rags and plastic for a week then I will proceed with a 3-inch layer of a 10:1 vermiculite/cement. A couple of questions though
1- should I air cure this first layer after the week long wet covered curing before the next step with vermiculite/cement?
2- Also, can I demold this first shell and move it to the final resting place (stand) and do the vermiculite/cement layer once it has been placed on the oven floor; or I should finish the entire oven and then do the floor stand process
