This is a wonderful site with so much information, thank you all the the wonderful resource. I watched a few YouTube videos about cob and brick ovens and got the bug and jumped right in. I have already built my stand prior to finding this site. I have a patio built out of 16 inch stepping stone set on gravel and sand. I took up one corner of the stones and poured a 5 1/2 inch pad to build my oven on then reset the stepping stones. I built the stand out of 16 gauge galvanized studs ever 6” and wrapped with hardy backer and poured a 3 1/2 inch table top. I did it this way Incase I ever wanted to move it. I now realize I was delusional. It’s going to weigh over 2000 pounds when all said and done. The stand is 52 inches round with a 30 inch extension for the entry. I am shooting for a 40 in high oven floor. The concrete top is 33” high.
I plan to build a 36” igloo style dome. I have already purchased a few things. 40 new medium fire bricks ($1.25) for the floor, 200 fire brick ($.30) seconds from a local manufacturer, 7 - 8.5” od round clay chimney liner ($11), 2” x 39.4x39.4” Simvac ceramic fiber insuulation board ($87) for the floor and Cera Materials refractory ceramic fiber insulation ($97) 6# 2300F 1” x 24” x 25’ for the dome - may need more to get 3” thick . And now after reading the FB site have lots of questions.
1. Will the Simvac ceramic board work under the floor?
2. Should the insulation extend past the wall of the oven.? Should I cut it at 45 inches 36+4.5+4.5 or should I extend it a couple inches past the wall?
3. How far should the insulation go into the entry arch?
4. The board is 2 inches thick but it seems the general consensus of the forum is it should be thicker, can I add a 1 inch layer of perolite concrete mix to the top of the board?
5. I plan on having a floating cooking floor over a sand/fireclay base, is 1/4 inch of mixed sufficient?
6. I plan on using sailors on the first course. Can I stack two or three courses without taper to achieve the same effect as a soldier course or would I still have concern with the outward pressure like the soldier course?
7. Has anyone slanted the venting towards the back of the oven with a couple 45 couplers? Will this cause significant concern with the draft?
Next step is to build a jig for the saw, an IT, and the arch forms. Thanks again for the wonderful site. I hope mine will turn out at least half as good as yours, you have all set the bar extremely high.
