Hi all,
First post. Been creepin’ the forum for a while, and been gettinbg alot of useful information, figured it’d be about time to sign-up.![Smile](https://community.fornobravo.com/core/images/smilies/smile.png)
I’ll get to my question, but just a bit of backstory. I built my first pizza/bread oven last year. With a budget of about $0. Used clay from my yard, straw from the field, sand from the beach, old bricks for a floor, and got away with a decent oven for the summer. It was small, but got up to great temperatures. Could cook a pizza in about 2 mins, and held heat long enough without fire, to do some bread baking. However .. it started to deteriorate over the winter (i believe the clay mix was way on the sandy side). So, i decided to dismantle, relocate my oven this summer, and still spend about $0.
I built a brick dome, instead of clay, using old chimney bricks, solid brick floor over a sand/bottle cavity (which worked well the year before). Covered my brick layer with vermiculite and cement mix. Approx 2”. And I have a very thin layer of clay on the outside, mostly to keep the vermiculite from falling away.
My issue. Oven is not getting hot enough, not holding heat, and not nearly as even as my previous clay oven. Granted, I know its differnent materials, etc.
Other Issue. My second firing got pretty hot, and some bricks on the inside started to flake and fire out the oven door like a pistol! I later learned, these chimney bricks are not meant for such high heat.
#1 do I need more insulation on the outside? Will it help, even if I can fire the oven too hot on account of the bricks breaking.
#2 is there something I can put on the inside (clay, mortar, cement?) to hold heat better, and deter the interior bricks from exploding?![Smile](https://community.fornobravo.com/core/images/smilies/smile.png)
Knowing that I will likely rebuild a third time at some point, if i’m not happy with it, is there a way to make this setup work better for a season, or do I tear it down, and go back to clay interior?
