What is the ideal size log to use for a 36" pizza oven.
Wood Size for pizza ovens
Tags: None
Just read in another post that 3" diameter logs by 12"-18" long are good....Anybody do anything different?My Build Pictures
Originally posted by Chach View PostJust read in another post that 3" diameter logs by 12"-18" long are good....Anybody do anything different?Kindled with zeal and fired with passion.
Thanks for the info. This forum is a plethora of knowledge and I'm very appreciative.My Build Pictures
I don't have a hydraulic splitter, and hand splitting now hurts too much the next day to be done routinely, so I use the wood as it comes from my tree guy, which is generally more in the 4-5" range. Having it thoroughly dry (3+ years old in our part of the world) seems much more important than the size. A rule of thumb is one year of drying time for each inch of thickness.My build thread: https://tinyurl.com/y8bx7hbd
How many logs do you put in when you start your fire?My Build Pictures
I've been building a stack with 5-6 good sized chunks of wood, a few fatwood sticks for starter, and some scraps out of my shop when they're available (this is in a 42" oven). After about a half hour I feed the fire another two pieces every 15-20 minutes. As the oven gets hotter the wood burns much faster. I look to have flames fully across the dome for the second hour of the heat-up phase. Then push the fire to the side about 10-15 minutes before starting cooking. While i'm cooking I like to have flames licking across the top of the dome, but not all the way, and not going up the chimney. I shoot for a floor temperature of 800-900 degrees. It takes about two hours for my oven to fully heat up and the dome to completely clear. I'm using wood a lot faster than I planned, I've just built more storage area for drying split wood. I'd like to reach the point where I have about three cords at all times, using about one cord per year.
It might be possible to pre-heat faster, but I figure it takes time to saturate the floor and dome and 2 hours before dinner is an easy time to remember to start the fire.My build thread: https://tinyurl.com/y8bx7hbd
Sounds logical....very excited to start this spring but this weather is depressing....tomorrow is -22 and -50 with the wind chillMy Build Pictures
No diameter wood is too small imo. The small stuff can be bundled. I use natural hay string with a modified "trucker's hitch" to sinch them up. These are dry wind falls. They had to be picked up anyway. Might as well use them. For starting a "top down" fire, they are priceless.1 PhotoJoe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
Originally posted by Gulf View PostNo diameter wood is too small imo. The small stuff can be bundled. I use natural hay string with a modified "trucker's hitch" to sinch them up. These are dry wind falls. They had to be picked up anyway. Might as well use them. For starting a "top down" fire, they are priceless.
Last edited by david s; 02-09-2019, 02:01 PM.Kindled with zeal and fired with passion.
This year I have to prune the pear tree so hope i can get some nice sized branches to use in the future. I have to start picking up all the twigs and small branches around the house I guess...Nice job for the kids to do this year...My Build Pictures
