Hi Everyone!
New to the forum and writing my first post here. I live in Acton Massachusetts and I have the intention to build a 42" this next spring / summer
My intention is to build a corner version and probably I'll connect with a few other elements to form an outdoor kitchen.
I've been reading many posts, I've read the PDF with the instructions, and I've been doing research for a while.
The time to get more serious with it has come, and as many of you, I have a ton of questions.
My first question: I think I want to pour the concrete top using a HardieBacker board, instead of wood. I've seen that people leave a few inches to the edge for the concrete to fill the wholes on the cinderblocks and reinforce the strength of the top. As the board will rest on the cinder blocks on the sides, do I still need to build support with 2x4's towards the center? or would the board be able to hold the weight of the concrete?
I haven't been able to find anything related to it.
Thanks in advance!
Thanks in advance!
) and if you can, make the ground support 2x4s a little short and then put in some easy knock-out wedges/shims under them to bring 'em up to contact with the board. It really helps to remove the 2x4s later cause as JR noted, you'll be amazed at how difficult it is to remove the supports with that solidified concrete slab pressing down from above. I used plywood scraps instead of the concrete board and cut pieces to fit my "gaps" and then lined the form with plastic. The plywood released quite easily from the cured concrete with the plastic liner (although as with JR, I had to use a sledge hammer to get some of the plywood supports out...and beating on support boards while under the supported slab is not my idea of fun
