I think i really messed up. 1 meter diameter oven.
At the end of the previous pizza session I loaded the oven with the wood for the mext burn and closed the door. The oven was 600+ degrees.
The ultra dried and a bit carbonized logs had a nice ring sound to them vs clunks when I started the next firing.
When i started the burn last night i had 2 large pieces on the side and 4 pieces cross stacked above.
They all caught fire very quickly and completely, typically only the inside of the og burns but this was all the way around.
Doesn't look like any damage other than smoke stain on the outside.... it just cam pouring out the chimney was somple overwhelmed.
Am I the only newbie to di this?
... which might reduce the amount of your facial hair and certainly might call for you to change your underwear in the near future.
). That said, you're only drying off some minor moisture that absorbed by the wood from the air or a brief shower...you should not be using the oven to dry out uncured/wet wood. Also don't forget that you need to provide moisture an exit from the oven chamber, so leave the fire door open enough for air to circulate.
