Would Pennguard block make a good floor insulation instead of vermiculite?
What are the specs?Russell
I found a statement in a Pennguard Block installation that notes the material is good to only 200°C. I didn't find any compression data...you need to have at least 100 psi from my perspective readings. As Russell noted above, you need to get a more complete data sheet on the product before you proceed exchanging any money for it.Mike Stansbury - The Traveling Loafer
Roseburg, Oregon
Thank you. The person who is selling them could give me no data..I will keep looking. I am hoping the start the foundation in the next couple of weeks. I was able to get all my cinder blocks for my raised garde bed and the oven from a guy in Morgan for .87 cents each.
I did do a google search, the data is out there, it appears to be similar to FoamGlas, which is a good "first" layer since FoamGlas will not absorb water. If this Pennguard is a good price it would be worth looking at. Here some data of K values of vcrete.1 PhotoRussell
Understand that.Russell
