Noob question! I felt it was more convenient to put the square of the ceramic board down and build on that rather than cut out the shape of the oven. Is there any problem with putting bricks on the ceramic board?
Can I put brick on top of ceramic board?
omg im such a dumb dumb i thought it said cement board it said ceramic lol my bad i probably should get more sleep...yes i totally agree with these guys. I am enclosing mine so i didmt cut the shape of the floorMy Build Pictures
The calcium silicate board I use does not get spongy when wet. It’s compressive strength is unaltered. I found this out recently when we were flooded. The calsil sucks up water incredibly, almost 4 x it’s dry mass. Other products can get soft and spongy when wet.Originally posted by UtahBeehiver View PostSpongy CaSi board? Do you know what the compression strength of the board is? I should be at least 75 PSI with 5% compression. There are some materials out there with lower compression ratings.Kindled with zeal and fired with passion.
