Hello all, first and foremost thanks for all of those who have posted, helped and shared tremendous wisdom on this site. Unbelievable.
I am starting the oven portion of my build, and have found a way to massively confuse my desk-jockey self on the build. Apologies if these are super basic.
Right now, I am planning a 43.5" diameter oven and am following the FB corner install plan.
1. How do I determine what brick angle (shim) to use as I build the oven? First course I am planning is half soldier but then wondering how I set the angles for course 2, 3, etc.
2. My guess is answer 1 might have something to do with the IT
If so, am I right in assuming the IT length should be the net radius of the oven? In this case would be 43.5"- 9" = 34.5" / 2 = 17.25"? (9" subtracted for the brick at 4.5" x 2). There's a great spreadsheet on the forums that produces a brick count and using that spreadsheet, length of the IT should be 19.9.
thanks to any and all for reading / help!
If so, am I right in assuming the IT length should be the net radius of the oven? In this case would be 43.5"- 9" = 34.5" / 2 = 17.25"? (9" subtracted for the brick at 4.5" x 2). There's a great spreadsheet on the forums that produces a brick count and using that spreadsheet, length of the IT should be 19.9.thanks to any and all for reading / help!
