need suggestions for my wood fire oven
  • need suggestions for my wood fire oven
    My oven dome size is Around 2'3" height, what should be door size and is it to high cas I facing issues with maintaining the temperature. Need suggestions please, guide
    The door height should be 63% of the internal dome height, so if your internal height is 27” then the door height should be 17”, but don’t sweat if it’s out, an inch or two higher or lower won’t make much difference to the performance. If your oven is new there may be other reasons it’s having trouble maintaining heat, usually lack of insulation or retained moisture.
      Thanks for the help, ya my oven is new and we gave prep for 4 times, We are working on that as well.
        Did you have any problems during the cooking process?
