I built a barrel oven all fire brick and then 3'' of perlite 7-1 insulating cement with 2 layers of stucco on top. after firing the oven slowly the last firing the stucco cracked along the top. i thought i had all the water dried out but guess i didn't as there was steam coming out of the cracks. The oven is in perfect condition, just the stucco render is cracked. I was planning on firing it a few more time and let the cracks act as vents and then add 2'' of insulation on top and re-stucco it. What do you think of this ??? or I was gonna fill the cracks in with heat stop mortar while the oven is hot and the crack is expanded. any advice is appreciated. thank you.
(I would) Dry it first and evaluate if you think the heat retention is to your likeing or not. If so, cut a 90 degree V in the crack and fill it with stucco again. Otherwise, try get the stucco off with a hammer and chinsel carefully. Add a second layer of perlcrete. Make it as lean as possible to make it crack rather than the stucco. Add the stucco in one go. I experience it gets stronger this way. Cover it for a week to cure.
Originally posted by plug2000 View Post...guess i didn't as there was steam coming out of the cracks. ...
Originally posted by plug2000 View PostI built a barrel oven all fire brick and then 3'' of perlite 7-1 insulating cement with 2 layers of stucco on top. after firing the oven slowly the last firing the stucco cracked along the top. i thought i had all the water dried out but guess i didn't as there was steam coming out of the cracks. The oven is in perfect condition, just the stucco render is cracked. I was planning on firing it a few more time and let the cracks act as vents and then add 2'' of insulation on top and re-stucco it. What do you think of this ??? or I was gonna fill the cracks in with heat stop mortar while the oven is hot and the crack is expanded. any advice is appreciated. thank you.Kindled with zeal and fired with passion.
