Hey y'all,
I'm just gonna ask some questions here instead of searching because that gets overwhelming for me instead of just direct answers. I'm starting my homebrew cast oven plans and need some help:
For the dome and insulating layers, I was thinking this set up:
Layer 1 - Sand, cement, hydrated lime, fireclay, fibers 3:1:1:1:1
Layer 2 - Vermicrete
Layer 3 - Ceramic blanket
Layer 4 - Another vermicrete layer
Layer 5 - Smooth finish (not sure of material but would like that look)
What thicknesses do I need for each layer?
What kind of fibers are best and how much?
Does there need to be a vent on the dome or will a flume at the top of the opening be okay?
As far as the insulating hearth, I'd like to use calsil instead of vermicrete because of time and easier to install. I already have the base and concrete slab up, so can it just sit on the concrete or should I use an adhesive? I want to double the floor insulation, so should I just stack two calsil boards on top of each other, or what would be a good way to achieve that?
These are just the beginning questions to get my plans rolling. Any input would be much help.
Thanks!
Thanks!
