At the end of April our hearth was poured (3" concrete + 4" of the vermiculite/concrete mixture), this ended up sitting for 2+ weeks due to construction delays. The floor was set, dome placed, 2 rolls of blanket overlayed, then 4" of vermiculite/concrete added over. Several days later the stucco was applied. From the date of the stucco the oven sat idle for ~10 days. Then the fun began, I started with a small fire day one (paper + kindling), day two paper + more kindling, day three paper plus even more kindling. At this time the interior of the dome was still covered with soot. On day four started the fire with kindling, added a piece of almond wood, then another 30 minutes later. On day five two pieces of wood and I finally saw white at the top of the dome! Day six I cranked it up and added three pieces of wood anad got flame coming out the front and up the flume for a few minutes, the interiopr of the dome went almost entirely white. Note: after each day I let the oven cool but the morning after day 6 is was at 300 degrees F. Day 7 I noticed two hair line cracks in the exterior of the stucco :-<
Now the questions...
Two days later went to cook for the first time (fire in center then moved to the side using almond wood) and the oven took 2 hours+ to get what I thought was hot enough...floor registered from 700 to 500 depending how far I got away from the fire, is this normal? or should I have been patentient and let it get hotter?
Dough was hand made and surely stuck to the peel almost every time...I think to many toppings were added plus not enough flour on the peel, any and all suggestions are welcome...
PS: my son graduates from high scool in two weeks and we have 50+ coming for pizza and wine...here's where I really need help
