Perlite Dome insulation quantity
  • Djeffrey
    • Mar 2021
    • 6
    Hi All, i'm looking to purchase some perlite just to be used for the dome insulation (over a fibre blanket). Ive read 50mm is a good thickness. Does anyone have any idea how much perlite this will require for a 1meter outside dome and 50mm thick? I have found somewhere that sell 100 litre bags.
    On a separate question how is best to waterproof, I have heard aluminium flashing between fire blanket and perlite but can only find it in strip form?
    Dave J
    • 5263
    On the dome 8-10 to 1 by volume is the appropriate ratio for insulation plus about 20%. You can calculate the volume of the OD diameter of a sphere and subtract the ID diameter of the sphere and divide by 2. Sphere volume calculators you can find on Google.
    • Djeffrey
      • Mar 2021
      • 6
      Thanks Utah, only just got access to this post.
