Hello, WFO lovers.
I am a really busy older woman but I do not eat “prefab” food. Generally I make everything from scratch, especially pizza.
A few years and one move ago, I created a WFO after watching this video:
I actually made it “permanent” in my yard.
For the base, I used a cast iron coffee table with a ceramic tile top. I got several hundred fire bricks for $40 from someone who was rebricking a chimney. I put down a double layer for the base, double layer walls and a double layer ceiling. It worked great for several years. I kept it covered and protected with a tarp when not in use.
When I moved into my current house, the hubby did not cover the firebricks before I rebuilt my oven and so they got wet and have gradually been disintegrating. Summer of 2019, I had pieces of brick flaking off inside the oven when I was cooking so I had to close down the oven.
For two years I have been trying to muster up the courage to put in a real WFO. I just can’t do it. I had to accept I just don’t have the skills, money, or energy to do it but I miss my pizza parties. My friends keep asking me when they are going to start up again.
I want to try something a little different so I found this video:
I am going to use the coffee table base with the double layer of firebricks. I think I have enough firebricks for the interior layer of both the firebox and the oven. For the outer layer, I am going to have to use bricks from my patio. These are red bricks from the 50s. I am not sure what they are made of. It doesn’t look like concrete because they are very smooth.
Here is my question: I want to make the oven 28-30 inches square on the interior so the 24-inch concrete used in the video won’t be big enough. Do you think I can cast a slab using the ‘home brew’ mix from David S AND embedded either rebar or hardware cloth that the cast slab would be strong enough to span the 28-30 inches?
Any suggestions on how thick to make the slabs for the oven floor and ceiling?
I am a physics teacher—spring break is coming up in a few weeks and I would like to make it then so it can fully cure before summer pizza party season.
Second question: where do I get SS needles and polypropylene fibers?
Thanks for any advice.
Barb
Barb
