Hi all
Writing from the UK - I've got to the stage of having my dome built of fire bricks, the ceramic fibre blanket is on covering the dome and chicken wire on top of that (got to this stage last year! but haven't progressed it as I'm now stuck).
What do i do next? i think i have to do a vermicrete insultation layer but some guidance would be appreciated.
I have bought some Micafil vermiculite which i was going to mix with some cement and potentially fireclay but i don't really know what I'm doing.
Is this the right materials to use? What would the mix be? is it 10:1 vermiculite:cement? Do i need to add lime or fireclay into the mix? How much water - would this not just make the ceramic blanket wet?
ande then - what can i render the dome with and what mix do I use?
I'm happy to go and source something else to render over the chicken wire and fire blanket if something else is better.
Any help with how to render the dome - or essentially what i need to do after the chicken wire stage would be so helpful and much appreciated - amateur girl builder but have loved putting something together with help from this forum.
have tried to add photos below - not sure if they will work but will give it another go if it hasn't.
