I am installing my cooking floor onto my 4.5-inch concrete hearth at the moment and was wondering how necessary a CaSi insulating board would be. I am over budget already and the CaSi board is rather expensive. What are the downsides of not adding that extra layer of insulation and will it have negative impacts on my oven? I want to note that my firebricks are heavy/super duty firebricks, which from what I have researched means they retain heat even more so than medium duty firebricks which means maybe another insulating layer would not be as necessary. Thanks, everyone.
You need to insulate under the floor and the dome edge or the concrete hearth will act as heat sink and the oven will not perform very well. The oven floor will not retain heat.
CaSi is the most effective insulation but you could install a 5 to 1 p/vcrete a min of 4" thick to equal 2" of CaSi board as a budget option. There are plenty of builders and thread regarding p/vcrete.
DO NOT skip the floor and dome insulation.Russell
- 2 likes
Ok well what will happen if you dont insulate under the floor, the heat from the fire will start to travel down through the bricks and then start to penetrate down into the concrete base under the bricks.
The whole mass of the concrete will start to absorb the heat from the fire until the whole base is finally saturated with heat, this might take many hours while all the time stealing heat fro the fire and stopping the heat spreading out and up the walls of the dome!
If you do use insulation ( and plenty of it) the fire will heat the bricks and then hit the insulation stopping it from going any further but reflecting the heat back up into the bricks making them much hotter much faster and allowing the fire to spread the heat out and up the walls.
So in effect you will have a much faster heat up time, hotter bricks and burn a fraction of the fuel.
Originally posted by UtahBeehiver View PostYou need to insulate under the floor and the dome edge or the concrete hearth will act as heat sink and the oven will not perform very well. The oven floor will not retain heat.
So why can't you pour a v/pcrete layer on top of concrete hearth? Yes CaSi is expensive but it is what it is. Most refractory supply shops carry CaSi (You wont't find this at HD or big box stores) Trade names would be ThermoGold 1200 (water resistant), IsoBloc, You just have to call around, Distribution International is a solid supplier but not the cheapest. Before you purchase any CaSi you should post the specs on the blog for review, not all CaSi are suitable. If you can install CaSi, why can't you install p/vcrete? PS If you have not already downloaded, studied and reviewed the free eplans from Forno Bravo, you should.
Originally posted by UtahBeehiver View PostSo why can't you pour a v/pcrete layer on top of concrete hearth? Yes CaSi is expensive but it is what it is. Most refractory supply shops carry CaSi (You wont't find this at HD or big box stores) Trade names would be ThermoGold 1200 (water resistant), IsoBloc, You just have to call around, Distribution International is a solid supplier but not the cheapest. Before you purchase any CaSi you should post the specs on the blog for review, not all CaSi are suitable. If you can install CaSi, why can't you install p/vcrete? PS If you have not already downloaded, studied and reviewed the free eplans from Forno Bravo, you should.
I'm calling around and the quotes I'm getting for 4'x4' CaSi are just too much for what I feel comfortable with at the moment. Would 3" p/vcrete be doable?
I think I have already explained why we use insulation and the effects of using too little but, there is nothing stopping you using less than the recommended minimum….it just means your oven wont work as well!
Have you looked for ceramic fibre board, it has slightly better insulation than Calcium silicate board but may be even more expensive where you live?
