Ok, I had to change my initial base design based on advice I got here previously. So floor is 6 inches concrete topped by 5.5 inches portland/vermiculite at 6:1. Dome is 4 inches thick fire brick, 28.5 inch inside diameter and 16 high. Opening is 15 wide and 10.5 tall. Chimney vent inside is 3 by 7 inches. Installed wire tabs sticking out of external dome to make attaching insulating mat and chicken wire easier. My questions are: I have half a bag of fireplace mortar left. Skim coat dome with it to use it up or no benefit? Biggest question is I'm tight on space from dome edge to platform edge, 3 inches. My plan is for two layers of one inch mat then one inch of rendering and that will get scratch coat of thin set using acrylic admix with pebbles rather than tile covering to improve water repelling but will likely add a simple single pitch roof shedding water towards rear.
OK Fellows, don't let me screw these next steps up.....
