I'm still in the paper planning and researching stage and have a few questions for the group. The attached is kind of what I am thinking.
The yellow is the dome bricks at 4.5" width, the white circle is CalSil blankets at 4", then about 3 inches of verm-crete with some sort of tile or something on the final layer. Red blocks are the concrete blocks and the slab/foundation. I was planning on overhanging the hearth 4" past the concrete blocks using 2x6's on the form so the foundation and hearth would be the same dimensions.
The main question that I have is on the vent/landing/chimney area which is light blue in the attachment. Is 2 full bricks plus a little overhang on the hearth going to be too deep to comfortably work in the oven? It looks like most people have 1.5 bricks on that area.
I have a 3" reveal on the oven to vent transition for a door with the outer arch being 1.5" narrower to hopefully trap the smoke. I can change that if the vent area is too deep or maybe use the thinner side of the bricks on the outer arch...
My foundation and block stand are a little less than what is in the plans, but is probably just due to rounding on the block size (15.625" vs 16" for cement block length).
Anything jumping out that I should address before I start digging out the foundation? I don't want to look back and say that I needed more/less area when it's past the point of no return...
-AJH
-AJH
