Hi guys,
I am struggling with getting the pizza oven floor hot.The floor is made of clay firebricks 2,5" thickness. When I heat the oven I do not see any obvious heat escape problems, i.e. the dome and the slab underneath the oven are touch cold. But my floor never gets hot enough. Even baking a bread is a struggle as it will bake on top but the bottom will be white and raw.
Are there any obvious things I could check? Maybe the door is too big, or chimney pipe diameter is too big? Or something else?
