Dome arches angles ??
  • Dome arches angles ??
    Hi building a 36inch dome going to do the arch templates is it critical that both inner arch template and outer arch template are the same angle understand about making outer arch abit wider was looking inner 500mm & outer 540mm but unsure how critical the angle is for both as you don't see arch and also any tips if both need to be same angle how to do that thanks Paul
