I am getting ready to build an oven in a backyard terrace, so I will
not be building a block base, the 1st concrete slab will be directly
on the ground then I will be adding the thermo layer slab on top of
it, then the cooking floor. The rest of the oven will be like any
other. I have included my parts list below and want to insure I have
not gone to overkill mode with materials. I chose the arch fire
bricks for ease of setting though most plans I have seen use the
straight fire brick. By using the arch brick I will get a 71/2" rise
in 3'3" which seems to be the goal of all the plans. Let me know what
you think as this is my first attempt.
Item Quantity
Hearth Plates Square Edge Fire Brick Tiles 12x18x3 6
# 1 Arch Fire Brick 54
Straight Fire Brick 9 x 4 ? x 2 ? 100
Refractory Concrete (Kastolite 22) 3
Castable Refractory Concrete (Mizzou Castable Plus) 3
Fire Clay 2
Hi Temp Mortar (Heat Stop II) 1
Sand 2
Wire 2
Stucco Mesh 2
Stucco Mix 2
Cool Tile for Decoration 10
Hearth Tiles 8
Chimney parts 1
Item Quantity
Fire Clay 2
Sand 2
Wire 2
Stucco Mesh 2
Stucco Mix 2
Hearth Tiles 8
Chimney parts 1
