can i put the fire brick on the concrete pad i poured its 3@half " thick
Re: iusulation
No - you need to insulate using the insulation board or a vermiculite / cement mix. If you just sit the brick on the slab, it will steal the heat away from the brick.Check out my pictures here:
Re: iusulation
I believe the standard size is 2 inches - I went with 4 inches thinking more is better (plus it got the hearth to a workable height). No need to glue it down, the weight of the brick works just fine.Check out my pictures here:
