Hello,
I am considering a purchase of the Toscana90, have a few basic questions about building the base and moving the oven on the base.
Once I pour the foundation and dry stack the cinder blocks, I will fill every
other hole with rebar / concrete. This means every other core / hole will still
be empty when I pour the structural hearth. From the Casa 90 instructions, it looks like I can use the empty concrete bags to keep the non-filled cores from creating a problem. Questions:
1. For the cores that span the angle iron / arch in the base, I don't think concrete bags will do. Do I need to build a form underneath those openings? Is there another trick?
2. If I do the Toscana 90 (so only a structural hearth, no insulating layer), is
3 1/2 inches thick enough?
3. I see from the instructions for the Casa 90 that cement backer board is layed down. It wasn't clear to me exactly what this is for. Does this backer board cover the entire bottom layer of the structural hearth? Is this on top of the plywood that is the bottom of the form? If so, does it go all the way to the edge (to completely cover the bottom of the structural hearth)?
4. I have found a crane company that will (reasonably) bring in a boom truck, load the oven move to the stand and place the oven. It does not look like there is a lift point on the oven. Will the company use straps? If so, how are the straps removed once the oven is in place?
Thank you,
Tim
Raleigh, NC
Thank you,
Tim
Raleigh, NC
