All,
I'm considering builing a dedicated smoker in the area under the hearth of the oven. The basic design I was considering was an offset reverse flow smoker with an arch ceiling for the smoking chamber. Basically I want to take the corner design like http://www.fornobravo.com/forum/phot...2828/1_005.JPG and replace the fireplace with a smoker. The firechamber and exhaust will be in the rear of the structure and the loading area for the meat will be where the fireplace front is. I will have a steel door etc. My question is what is going to be my best method for building the hearth and insulating the smoker?
layers as following:
OVEN
INSULATING CEMENT LAYER
CEMENT LAYER
CURVED FIREBRICK ARCH
SMOKER CHAMBER
SMOKER FLOOR
INSULATING HEARTH LAYER
CEMENT HEARTH
How should I suport the arched firebrick layer when adding all the weight above? Will this be able to support the weight onces curred (I assume a lot of the stress will be removed with the addition of the Solid rebar reinforced cement hearth layer of the oven). Do I need to poor the oven layer first and then build the smoker layer later? I'm new to masonry but I learn quickly. I was thinking the smoker might resemble the oven in this video (YouTube - Woodfired bread/ pizza oven construction) when it's all said and done. Basically take that, and create an offset portion in the rear (basically make it lower) then add some reverse flow characteristics to even out smoker temp and ensure the proper smoke temps etc. Would you go with loose insulation for this layer?
OVEN
CEMENT LAYER
SMOKER CHAMBER
SMOKER FLOOR
CEMENT HEARTH
