Just a thought
  • mikeye15
    • Dec 2008
    • 29
    Just a thought
    OK I know this is not a WFO question. I am also planning a true BBQ pit next to the WFO. Would you use vermiculite morter mix to fill the masonry block cavity of the oven walls or is that overkill.
  • nissanneill
    • Apr 2007
    • 1886
    Re: Just a thought
    Mikeye15,
    Vermiculite is an insulator and your cement blocks are a heat absorber (although cement is not recommended to get too hot as it will break up and self destruct over a short time).
    You will be gaining little using vermiculite apart from a little weight. It is also not as strong as Portland concrete.
    Neill
    Neill’s Pompeiii #1
    Neill’s kitchen underway
    • mikeye15
      • Dec 2008
      • 29
      Re: Just a thought
      I get it. I would actually be hurting myself because I would insulate at the first half of the block. It is a low heat pit probably stay at around 250 F. I want it to hold the heat.
      Thanks for the input
      • Chef
        • May 2008
        • 175
        Re: Just a thought
        Mikeye:
        We built a BBQ pit next to our WFO for the floor of the pit we used refactory cement. Just as an FYI make a cover for the BBQ so the cement does not get wet, after the sprinkler system wet ours and we used the BBQ the cement would "steam" so we now keep it dry with a wood cover.
        Check out our blog for a glimpse into our hobbies of home brewing, soda, beer and wine, gardening and most of all cooking in our WFO!
        http://thereddragoncafe.blogspot.com/
