I am building a brick oven in my backyard I am almost finished but I was wondering is a chimney necessary
Re: chimney
It is actually a vent set just outside the oven dome at the same height as the top of the door opening.
An pizza oven will work just fine without this vent, but the vent will help to reduce the smoke and hot gasses in your face as you work the oven.
Re: chimney
I think "fine" can be a relative concept. :-)Originally posted by Neil2 View PostAn pizza oven will work just fine without this vent, but the vent will help to reduce the smoke and hot gasses in your face as you work the oven.
There is a lot of wiggle room with brick oven design and building, but I don't think I would consider building an oven without a vent and chimney. If you are going to the effort and cost of building an oven, I would do the vent and chimney. The oven draw, heat movement, and the way smoke leaves the oven are so much better.
