Wondering what kind of supplier carries this stuff Fudugazi
Fireclay
Fire clay
Fire clay is a clay made up of aluminate and silica. You can buy it in a 50lb bag from your local brick supplier, but probably not Home Depot. It has many of the characteristics of a true refractory mortar, such as its ability to withstand high heat. That is why you add it to a traditional mortar to withstand heat. When you mix fire clay with portland cement, you get a mortar that is more heat resistant than concrete (portland cement with a sand and gravel aggretate), but much less resiliant or thermally conductive than a true aluminate mortar. Don't forget that portland cement burns out at a relatively low temperature.
Here in Sonoma county, you can get fire clay from our big, local masonry supply company, SBI -- who is also a Forno Bravo oven dealer
For an easy to work with (but less resilient) mortar:
1 part portland
3 parts sand
1 part lime
1 part fire clay
For a more permanent, but harder to work with mortar:
1 part calcium aluminate
3 parts sand
1 part lime
1 part fire clay
For an easy to use, long lasting mortar (but a little more $), you can buy Refrax from Forno Bravo.
http://fornobravo.com/installation-e...cessories.html
It's a real, pre-mixed refractory mortar.
-J
