Hello all,
I've been wanting to build a brick oven for a while now and for one reason or another have put it off, but I finally think the time is here. I am the type of person who does lots of reading, lots of thinking, and lots of research before I build. I am also the type of person who like to do things a little bit different. So as a result of those two things, I have a basic idea of what I want to build, and am looking for some feedback on problems I may run into.
I'm thinking a small dome shaped oven, only about 24" inside diameter. I wanted to build a earth oven, but I'm a heat freak(I grill at about 1200 F) and they just don't seem to get hot enough for me, so I decided to go a bit different route. I want to follow the basic procedure for an earth oven, but only make the dense layer 1" thick. Once it dries I then want to empty the sand, apply a low temperature glaze, and then attempt to fire it into a ceramic using the basic ideas Nader Khalili created to make ceramic houses in the middle east.
I then want to put a layer of castable refractory cement on for thermal mass, and then a layer of perlite/cement mixture for an insulating layer. Obviously this would all be on a insulated base with a standard fire brick hearth.
Anybody see major issues in this crazy idea? If I could make it work I think having a ceramic interior would be great.
