Hi all, I'm new to the wood fired world, and I've got a couple questions... I want to (eventually) have a wood fired oven inside my house, and I had an idea as to how to pull this off with a fireplace as well. Is it possible to build a fireplace and oven into one unit, i.e. having the fireplace on the bottom, and building the oven above it (having a gap all the way around the cooking surface for heat transfer to the top). This way, you could have one fire for both the hearth and the oven, and it would open up space in the oven (since the fire wouldn't be on the same level as the food).
I assume there may be drawbacks to this design in terms of heat loss, ventilation, even how to design it so that the top level has a gap all the way around it, keeping it strong enough not to topple.
Thoughts?
Jeremy
Thoughts?
Jeremy
