Ok, so i have nearly sourced all the bits needed for my 40" WFO.
I have decided to use solid clay pavers for the dome as firebricks as $6.00 each in Adelaide. I am tossing up wether to use the same clay pavers for the base or to use 300 x 300 x 50mm fire brick tiles for the base. I can get these for $15.00 each so that seems reasonable. Does anyone see any problems using the two different materials?
Also does anyone know where to get 390x190x190 concrete blocks for less than $5.50 each?
