32" Oven Big enough?
  • #16
    Re: 32" Oven Big enough?
    Boy, I'm impressed !! Thanks for the great photos. I think I'll use them in helping with my build. My foundation is excavated below grade also (due to topo isues) so that helped a lot.
    • #17
      Nice to see another NC oven build. I am in Charlotte and planning ground breaking after the weather gets a little warmer ( and wife gets off my back about all the other things I need to do first!).
      Keep us posted, look forward to seeing your build. I might just have to plan a trip to Asheville!
      Jason
      • #18
        My oven is only 21" diam yet by removing the coals and maintaining a small fire on the side I can still fit 3 x 9" pizzas in. I only use this method if cooking for more than 30 people, usually, like everyone else I cook one pizza at a time. A smaller oven is way quicker and cheaper to build, uses less materials, takes up less sspace and weighs much less.
        • #19
          Thanks for the tip. Yes, it looks like I may have to go smaller, but I still want to stay with a brick oven and a cost of under $1,000 if possible. It's the oven arch/vent area that's casuing me headaches. I guess I'll just have to place with some designs. I was considering a clay horno, but it's not brick.
          • #20
            I agree with you!
            The Office series dvd
            The Tudors series dvd
            Smallville box set
            one tree hill box set
            Will And Grace dvd season
            • #21
              has anyone done smaller ovens less than 32"?
              http://www.fornobravo.com/forum/f2/o...-nz-14012.html
              • #22
                Mine is a barrel vault, 22"W by 36"L, and I anticipate putting at least 2 12" pies in at a time. Nothing is too big or too small; it can only be wrong for your needs.
                • #23
                  Mine is 540 mm (21") and is ideal for us. It is the way you manage the space that is the key. We cook one pizza at a time, most do this anyway, it is the preparation that takes the time. We can cook three 9" pizzas at a time if feeding a big crowd. We usually finish by cooking a loaf or two of bread. The advantages of a small oven outweigh its limitations in my view, less materials, cheaper and less time consuming to build, takes up less space, lower fuel consumption, lighter and therefore no massive foundaations.
                  • #24
                    @David S
                    Does the 21" have enough thermal mass for a roast?
                    • #25
                      Yes, We use it to do roasts a lot. Oven wall thickness 2 1/2 " floor thickness the same.
                      • #26
                        Did you make the dome from castable or Firebrick.
                        • #27
                          I used castable for both the dome and floor.
                          • #28
                            david s - why does almost everyone I talk to say that I 30'' is the minimum size, and you are happy with your 21''? Do you have a technique that others don't know, hehe
                            John
                            • #29
                              The tradition of a large oven goes way back when it would be used for large families. How big is your normal kitchen oven? Therefore why would you want your outdoor oven larger? I have cooked pizzas for a party of 80 and we cooked 70 9" pizzas (3 at a time) in my little oven. I did refire it once, which took out about 25 mins of cooking time. Generally I'm quite comfortable to cook for a crowd of up to 30. I usually take out about 2/3 of the coals and maintain a fire on the side. Because space is limited I made a cradle for this side fire from 2" wide thin stainless bent and joined in the shape of a D The curved part of the D sit against the side oven wall and leaves enough room for cooking. I half fill the cradle with coals, blow the ah away from the floor and throw finger sized sticks into the cradle to maintain flame. I usually only cook one pizza at a time. It is the preparation of the pizzas which takes the time not the cooking. Always try to have another pizza ready to go in, so you are cooking constantly.
                              • #30
                                I have seen more designs around 21-23 inch size so don't feel were picking on you for having a wee one David were just interested in what you have done and contemplating a similar design. Thanks for sharing your experience and build details.
                                What size is the door way in your oven?
                                Regards
                                Bart
