Hi
Has anyone uses a slab of granite for the floor of their oven? I was thinking of laying common red bricks ontop of my concrete hearth with a layer of sand then the grannite slap on top. Fire Bricks are NZD$6.50 each over here and I have a piece of grannite big enough to cover the floor of the oven. I picked up about 60 second hand fire bricks for NZD$3.00 ea (Not enough). Has anyone made an oven using a combination of Fire Bricks and red clay type bricks? I was thinking of using the fire bicks for the top portion of the dome and the common red bricks (approx 60 years old and I have about 1600) on the bottom half of the dome. Do you think there maybe an issue with this. i.e different thermal expansion rates of the bricks causing cracking?
Your help is appreiciated
Cheers Andrew
Cheers Andrew
