I am in the process of casting the dome of my oven i am in the UK and see that there are various products available i guess castable 1400 (Refactory cement) is what i need but does it need reinforcement such as fibre added to reduce cracking. also i have read on the net that it is not such a good idea to cast in one so should i cut the dome into 2 or 4 segments after it has cured then cement back together. (I guess this will work as an expansion joint) Any ideas on this project will be greatly appreciated. Thankyou
Casting my first oven. Help
