Re: Are pizza ovens a major source of pollution?
Wood stoves with very limited draft for high efficiency can produce some pretty ugly molecules hence the modern designs with catalytic afterburners. But a pizza oven with the door open will have gobs of excess air so you should mostly be putting up C02 and some small amount of soot. In a bowl like LA you might not want to add more pollution into the soup but for most of us not a big issue. Buy a hybrid and come out ahead??
Dmun is right on one count, if the wood was just going to rot away, probably less greenhouse gas effect from burning it.
