Mixing Insulating Concrete
Re: Mixing Insulating Concrete
Using my concrete mixer, I found the vermiculite particles were breaking down, producing a denser = less insulating material. I eventually mixed it gently in a wheel barrow. I used 5:1 for under the hearth and 12:1 for the dome insulation layer.Comment
I'm wondering if someone could put, say, crushed stone, rocks, seashells, etc. over that perlite/cement finish you're showing in the first picture instead of the bricks you're showing in the second picture?
KasinH.
I covered my whole dome with it and it worked fine for me. Started at the bottom and built it up in a thick layer. I did have an initial layer of used firebricks which I'm sure helped as it gave me a terraced effect. I did add a small amount of fireclay which I believe improved the workability. I cut some of the layer off with a handsaw for my entrance and it was a lot like styrofoam, fragile but it floated too! I had a very high perlite
ortland ratio.Comment
