Outdoor Fridge
  • Outdoor Fridge
    If you have one, do you really use it enough to make it worth it? It seems like a cool idea but the cost of buying and operating one seems to be a bit silly. I don't have an outdoor kitchen yet, building it this summer, so I can't speak from experience so I'm looking for advice.
    Shay - Centerville, MN
    My Outdoor Kitchen/Pompeii WFO Build...
    Re: Outdoor Fridge
    Shay,
    I thought long and hard about this as well. Because of the cost of operation, I opted not to do it. I have a fridge in the shop, game room, garage, and obviously the kitchen. Cold beer is always at hand. If a fridge is not close to your oven, I say do it. Where you live, the expense of running it is not required in the winter.
    JMO,
    Les...
      Re: Outdoor Fridge
      That is true.. it's only for a few months of warm weather.. but I have a keg on tap in the garage! ack..
        Re: Outdoor Fridge
        I thought briefly about buying a commercial pizza prep station, which keep the trays of topping ingredients cold, as well as having a refrigerator area underneath. They're always available used, and they aren't that expensive. In the end it didn't seem that practical, and I didn't know how a refrigeration unit would work outdoors. So for me, it's back and forth to the kitchen.
          Re: Outdoor Fridge
          I have an "outdoor" fridge for my beer fridge in my tool room-soon-to-be-Mancave, and use it often. I debated one for the out door kitchen but decided against since it would not be used 70 percent of the time.
            Re: Outdoor Fridge
            this might seem like a silly statement...
            But.. You don't have to run it the whole time...
            personally, I hate running back & forth to the kitchen to get stuff out.
            If I had a prep area next to my oven, I would definitely put one in.
            I would use it to store & retard proof the dough balls, store all my toppings, etc etc etc.
            I also hate having to re-arrange my regular fridge to keep all my pizza stuff in there before a party.
            I'd just turn it on the day before i wanted to use it.... and turn it off the day after.
            My 2nd Build:
            Is here
              Re: Outdoor Fridge
              Conversely, you could just install a true ice box. The only operating cost would be buying the ice for it. One of the new high performing coolers mounted upright with a bottom shelf to separate the ice from the food would work wonderfully - and be super easy to clean.
              [/CENTER]
                Re: Outdoor Fridge
                Actually, a friend suggested building an ice box into the kitchen with a drain valve. That sounded like a neat idea. I'm still debating though.. sure would be nice to have that fridge.
                  Re: Outdoor Fridge
                  It will take a couple of days for a full or under counter size fridge to cool down, so it is cheaper to run it all the time, plus mold issues with turning it off. For me, an under the counter fridge isn't big enough to be useful. I have icechests that are bigger.
                  I also have an extra full size fridge in the "little kitchen" which I am about ready to seize control of and rid it of excess beverages and leftovers.
                    Re: Outdoor Fridge
                    I have a small under cabinet fridge in my outdoor kitchen area. Its sole use is for beverages. I believe it is a 3 cu. ft. model, holds about 4 - 12 packs in cans, maybe 24 longnecks.
                    I can't say it costs much to run, my electric bill is in the stratosphere, with or without it. I have found it indespensible when lounging around the pool, doing yardwork, or while firing my oven; I can easily go through 6-8 beverages on a hot day of yardwork, beats running inside every 15 minutes and letting a huge blast of AC air out of the house every time; I couldn't do without it at this point.
                    RT
                      Re: Outdoor Fridge
                      The wife and I have pretty much decided on a drop-in ice bin instead of a fridge -- figure the times we'd really use it (ie, parties, etc), we could just fill it up with a couple bags of ice and drop in a couple cases of beer and/or soda.
                        Re: Outdoor Fridge
                        So cheat. Go ahead and run the wires as if you were going to put in the fridge. If the ice box doesn't work out exchanging it for a fridge won't be much of a hassle.
                        [/CENTER]
                          Re: Outdoor Fridge
                          I like that idea, too. Just remember to consider draining in your plans - getting ice in is much easier than getting water out unless you have some sort of drain.
                          [/CENTER]
                            Re: Outdoor Fridge
                            I'm tempted to modify a cooler to be a standup cooler with a plexi partition which I can put ice in. That way the back is full of ice while the front is like a fridge. The lid would become a door and to fill it I'd just slide it out and open a door I'd make in the now top of the cooler. hmmmmmm
                            The original idea was something like a bench but one thing I hate is asking people to move so I can get something out of their seat.. very annoying.
                              Re: Outdoor Fridge
                              I'm in Virginia and it is 100 deg today, I bought an inexpensive $100 fridge probably 5 years ago and use it in my outdoor kitchen without problems. I bring it in the winter and put it back out. I could replace this fridge 7-10 x for the price of an outdoor fridge but I haven't had to, and it works great.
