I have a bit of a dilemma about what I want to do for the countertops in my BBQ/kitchen area. I have the area framed in and sheathed, and am still undecided about what material I want to use
My goal is to have something attractive, but not to break the bank putting it in. I am considering three options
The first two options are using granite. I have access to two pieces of granite slab that I am 99% sure I can make work for the space. A friend built a house and because of timing issues ended up having to double order granite. So this piece is now sitting on the side of his house under his trash cans (!) and he wants to get rid of it.
I can make it work if I go with a 4 piece approach:
1a) is to have a contractor pick it up, cut and deliver/install the granite. Advantage: that I make a call, write a check, and it's done right. Disadvantage: Best quote I have is over $900.
1b) is to get a wet saw and polishing pads and cut it myself. Advantage: Pretty cheap - probably less than $200. Disadvantage: I have no idea what I am doing, and I could screw it up. Especially given the corner seam cut.
The other option is concrete
2) Pour in place concrete - 1 1/2 thick. Advantage: Cheap - probably about the same as DIY granite, and no seams. Disadvantage: more work, unknown factor (haven't done before) and I am not 100% sure how to configure the back edge where the countertop meets the existing concrete wall
One other factor I am considering is that I still want to pour concrete for my oven landing - so there may be some economy of effort there if I go with concrete everywhere.
Any advice?
Any advice?
