Nashville, TN. Outdoor Kitchen and WFO Build - Forno Bravo Forum: The Wood-Fired Oven Community
  • Nashville, TN. Outdoor Kitchen and WFO Build
    Hey All,
    This is actually my first post. I have been reading this site for a few weeks now getting ideas for my outdoor kitchen which will have a 42" brick WFO and a custom built grill. I am currently getting ready to finish the forms on the pizza oven structural support slab. Here are some pics showing the progress from the start to now including the build of the custom grill.
    This is the clean slate and my little helper
    This is the orginal foundation slab for the outdoor kitchen before we decided to go crazy and do the pizza oven so I had to make a few minor adjustments.
    More pics to come
    Start of the Outdoor Kitchen Thread http://www.fornobravo.com/forum/f35/...ild-18433.html
    Oven Build Thread http://www.fornobravo.com/forum/f8/j...ild-20791.html
    Re: Nashville, TN. Outdoor Kitchen and WFO Build
    Here are some more pictures and this time I figured out the thumbnail thing on here. First pic is the block walls for the first section, the custom grill I am building will be in the center. Third pic is all the block done and the forms up for the concrete countertop. The fourth pic is the rebar reinforcment for the counter top all welded together and ready to set in place.
      That's a beautiful looking slab.
      Keep the pics coming!
      Ken H. - Kentucky
      42" Pompeii
        Thanks Ken,
        I actually just posted some more pics, they should show up in a little bit, after it gets reviewed / approved.
          Here is the next round of pics. They are all of the countertop pour. Next up is the building of the grill.
            Hey Steel and Stone,
            If you don't mind I would like to add your concrete counter pour to a thread I started on concrete counters. Are you hard troweling or polishing?
              UtahBeehiver,
              Feel free to add anything you like to the thread. I normally hard trowel just about all the tops I pour. I do have polishing equipment and have ground some down to expose the aggregate but most of the time I hard trowel and then come back with a slury and trowel that in to add some marbling. All the countertops in my house are also concrete, I guess I am addicted to them.
              here is a pic of the master bath top in my house we sold in Florida. I also cast the concrete vessel sink.
                Next up was to build the grill. I decided on sort of a hybrid I guess you could call it. I like the argentine style grills with v-grates and the ability to adjust the grill grate height but most of them are an open style and I still wanted a top on mine as we do cook a lot of low and slow stuff also; so I came up with a grill that has the v-grate, adjustable height, and a three section cover. Here is the first round of the fabrication pics of it along with the test fit. I figured this way if I measured and cut anything twice and it was still too short I would rather find out now.
                  In these pics I welded on some of the side supports and the uprights with the bearing carriers for the crank shaft that runs from side to side.
                    Wow, nice metal work. Those Argentinian's know how to grill, spent a couple summers in Bueno Aires.
                      Thank you and that would be cool! I had never grilled on this particular style grill before but loved the fact about the grate moving up and down to control heat and sear as well as the v-grate catching excess grease and channeling down to the front into the drip tray preventing most flare ups. We have cooked about 6 times on it so far and I have to tell you it really works awesome.
                        Here is the next round of grill photos. They are of the three section top and also a shot of the first mock up of the firebrick lined fire box.
                          This is the fabrication of the grate itself. 3/4" x 3/4" x 1/8" angle. Finished size ended up 34" wide and 22" deep. Weighted in at a whopping 34-1/2lbs. I hope it should last a few years.
                            now that is a grill.....
                            chip
                            Chip
                              Thanks Chip,
                              Here is the next series of pics.
                              The front and side vents cut out, the hand hammered hinges, lid lock and handle. And finally the completed grill painted and set in place. The entire fire box section is lined with firebrick splits, and has a 2" layer of insulating concrete under the firebrick floor.
